Link to full article here Quick overview: 20+ chassis get mobility changes. No exact details given. Heat system and stealth armor reworks. Stealth armor no longer halts all dissipation, but produces 1.5 heat per second. Heat system now removes destroyed heat sinks from the top, rather than the bottom. Basically, if you lose a heatsink after patch you may suddenly be overheating, whereas before you would simply cool down slower, and your minimum temperature was raised. Likely another attempt at nerfing energy heavy builds. Some QoL updates to the Social UI (finally) and FP. Bolt-ons updated to new mechs.
