I was messing around with the orion and I tried to achieve an asymmetric XL engine build on this chassis... And the result was unsettling this build. _ On paper you should be able to right peek with full alpha strikes up to medium range, but the weapon choices, different projectile speeds (especially MRMs) and the usage of an XL engine on such a huge build is... debatable, to say the least. This is a garbage fit: use at your own risk (and mockery).
XL on an Orion? That ridiculous left torso gets stripped and then focused and destroyed nearly every game. I pretty much assume that in the Orions I will spend a significant part of the match without my left torso. In some builds I actually COUNT on attracting as much damage as possible to that torso - put something colorful or a face on it to make it stand out even more.
