Casual NTG-H "RattlerGUNZ start a new thread" (4xcUAC5, TC1, ECM)
4/5,
1 rating
Thread in 'Night Gyr Omni Builds' started by Remover of Obstacles, Feb 14, 2019.
  1. Lorgot
    Lorgot Advanced Member
    403
    72
    Ghost heat, reeeeeeeeee
  2. The Verge
    I ain't afraid of no ghost [heat].
  3. Shock
    870
    353
    Heat penalty for 4th UAC5 is 0.4 additonal heat.
  4. Lorgot
    403
    72
    But it’s a uac5 so it fires twice, and very quickly so that extra heat will creep up on you(though the jam will prolly be there first)
  5. ShooterMcGavin80
    519
    Nah, the jams will prevent you from having too horrible a problem with the ghost heat.
    The posted build uses a Jade Kite arm omnipod. If you don't want to use a hero omnipod, here is the build with a standard NTG-C arm:
    Also the original build shaved a little more armor off than I would be comfortable with. Took off the TC and upped the leg armor.
  6. ShooterMcGavin80
    519
    There are a few different 'meta' NTG dakka builds. This is one of the weaker ones, but it is still good. Run it on the NTG-B for set-of-eight coolness:
    You can also run it with ECM:
    The other 'Meta' NTG dakka builds would be:
    1xUAC10, 3xUAC5
    5xAC2, 1xUAC2 (or 5xLB2X, 1xUAC2)
    3xUAC10 is also doable.
    1xUAC20, 2xUAC10 is also possible, but starting to get crazy and short on ammo.
