NSR-WP "Face Tank" (4x MRM20, 4x ERML, LE345)
1 rating
Thread in 'Wolf Phoenix' started by lonewolf8209, Oct 20, 2017.
  1. lonewolf8209
    lonewolf8209 New Member
    Not much you can do with this mech. tried 4 MRM 30's with 4ERMED and it was too hot. 4xMRM 10's was too little damage but this build is pretty decent. you can chain fire your ERMEDS on 1 and chainfire or fire all of your MRM20's without much heat build up.
  2. Excalibaard
    4,669
    1,022
    This, and 2mrm30 2mrm20 are probably the best thing to do on the Wolf Phoenix.
  3. CarloArmato
    1,800
    542
    29% heat efficiency is damn hot.
    STD325 version, 2xMRM30 (no ghost heat), way more cooling, less ammo (1200 MRM unskilled... More than enough IMHO, I don't think you will often last more than 20 alpha strikes, 24 with skills)
    LE325, 4 ton ammo, more armor stripped TC1
    EDIT: or simply drop the LE345 for a LE325 and fit more DHS... 33% should be barely manageable
  4. Excalibaard
    4,669
    1,022
    also possible. ghost heat on dual 40s is negligible. Dual 30 with a few ML is the same firepower as my Marauder but it weighs more and moves slower.
