Possible on all variants, but you only need PRIME and B omnipods. High LPLs for poke, 5MPLs in the arms to trace. Probably super-meta-viable if the profile allows. Is anyone else amazed at how perfect the stock NCT-A is?
So there are two ways I run this build, one with JJ's, one without JJ's. In both cases I run a TCIII. Alternatively you could drop the TC3 for a TC1 and add another two sinks--your choice (requires splitting the large pulse between torsos. The one with JJ's loses a single cMPL, while the other trades the JJ's for another cMPL; once again your choice. The TC3 gives a nice bump in lazor range with an appropriate skill tree, the optimal will be near ~690 for the cLPL... not too shabby. Edit: didn't see the "peak performance" build several below this one (I blame my tiny arse monitor), although this is slightly different it can be deleted if admin does not want such close builds. With JJ's Without JJ's
5/5, This build is one of the best Nova Cat builds. It delevers so much pinpoint damage for lasers. It play very nice.
