MAL-MX90 "Pepper Shaker" (6xAC2, XL325)
4.8/5,
5 ratings
Thread in 'MAL-MX90' started by enileph, Sep 16, 2015.
  1. enileph
    This is more fun than the KGC version for some reason.
  2. VanBurenPhilips
    VanBurenPhilips Active Member
    75
    Rated 5 stars, with caveat: I run mine Std and can't comment on XL as I've never put one in a Mauler so far.
    I love this thing! Big fan of rapid fire ballistics. I struggled through a few attempts at brawly builds for the MX90, then put 6 AC2s on it and instantly felt at home. First game:
    AC2s don't need as much cooling since the rebalance. I tried this build with 11, 12 and 13 DHS and found 12 was enough for me.
    Jackhammer likes this.
  3. Spheroid
    Spheroid Well-Known Member
    202
    With cooldown module 5 for the AC-5, the highest dps build is not what you may think on the MX-90.
    mauler data MX-90
    2x ac-5 + 4x ac-2 = 7.257 + 11.764705 = 19.0217 dps 40 tons
    3x ac-5 + 3x ac-2 = 19.710 dps 42 tons
    3x ac-5 + 2x ac-2 = 16.768 dps 36 tons
    5x ac-5 = 18.1448686 dps 40 tons
    6x ac-2 = 17.647 dps 36 tons
    other maulers (15% ballistic, fastfire, and cooldown 5)
    4x ac-5 = 17.71793
  4. dranozir
    Excellent build : I realy need to drop my medium laser for more Ammo ^^
  5. dezzik
    dezzik New Member
    Have been using this build for a fair while now and it has never failed me. DPS (with the right weapon groupings) is insane.
    Variant: can run a STD engine instead of XL, can also sacrifice armor for ammo.​
  6. You can drop the case and spend that ton on ammo or backup lasers.
  7. Excalibaard
    5,055
    1,107
    Merged threads.
    Welcome to Mechspecs dezzik! Next time when posting a build, please use the search function to check if someone has already uploaded something similar. The FAQ defines what constitutes as a similar or different build.
    Enjoy your stay and happy mechspeccing :D
  8. dranozir
    Finaly with just AC2 its better !
  9. Malystryxvof
    Malystryxvof New Member
    just bought this thing yesterday on the sale.. Modified the mech a bit from the builds posted here, but i'd say it works well... 2nd drop scored 1200+ dmg, and this is 4th drop in the mech.
  10. Hunter Joker
    Hunter Joker New Member
    Can You post Your revisited build?
  11. Malystryxvof
    here is how i tweaked it a bit.
  12. Ruludos
    Ruludos Benefactor
    88
    51
    If you change the http: to https: it will show the loadout card instead of the link.
  13. Malystryxvof
    appears i need more ammo in it atm though I ran out towards the end of the match....o_O
  14. CarloArmato
    Excelent build for Faction Play in hot maps.
    It can be upgraded to a Light Engine version with FerroFribrous, further enhancing the survivability of this build
  15. Excalibaard
    5,055
    1,107
    Nice build, BUT AVOID THE XL ENGINE VERSION. Light engine makes is much more survivable and better. Eventually replace a few of the AC2s with LBX2s for added crit but shorter effective range.
  16. Excalibaard
    5,055
    1,107
    Using a variation of this build in Solaris. Worked well at the start but the mauler really lacks the armor quirks that all the annihilators bring.
  17. CarloArmato
    Not only that: annihilator has better shape and hit boxes: you can easily spread damage on any annihilator, while Mauler torsoes are huge.
    IMHO Armor / structure quirks would only partially fill the gap... And that's really a shame, it would actually be a nice assault.
  18. Excalibaard
    5,055
    1,107
    spreading damage rarely happens in D1 I've found. It's just take full front armor and run at eachother in a DPS measuring contest. if you turn away, it takes so long to go back that you're losing DPS that you could be spending firing.
  19. I agree with LE over the XL engine. I would consider making room for two small lasers.
