MAD-4A "Standard Burn" (3xLL, 5xML, LE360)
Thread in 'MAD-4A' started by ShooterMcGavin80, Apr 14, 2019.
  1. ShooterMcGavin80
    ShooterMcGavin80 Well-Known Member
    179
    This is what I'm going to give a try. Standard lasers, standard heat sinks!
    Quirk looks like it is going to be 10% burn duration. Fully skilled with another 15% and your standard lasers should be almost as good as pulse lasers on burn duration. But with better range!
    Gun Tuv likes this.
  2. Excalibaard
    4,395
    975
    219
    I like it! I'm definitely trying out something like this as well, if the quirks are as you say. Made a version with the most possible SHS for funzies:
  3. ShooterMcGavin80
    179
    Woa! awesome that is possible. 36.4 kph probably unworkable though :)
  4. Excalibaard
    4,395
    975
    219
    Definitely unworkable, my build is hot meme garbage ;)
  5. Dagonus
    438
    112
    156
    I definitely ran the SHS version to get the event done on the 4A since I had the 4A(S) and wasn't about to spend cb on the 4A.
