I enjoyed my other pirates bane build so I decided to try a long rage sniper build. with my laser build I could get behind the enemy quickly and hit them. in some placed they turned around and didn't see me when SA was activated. but I haven't had much luck with this build. it looks cool but if you are spotted by another light. unless you are good with firing PPC on the move at high speeds your done. unless you can lose them. the ERPPC allows for longer rang but higher heat and a bit lower speed and no minimum range the snub nose PPC allows you to keep your speed and drops your minimum range
