Since 8 spl gives ghost heat, I removed a few for better heat dissipation. This is necessary because unlike the LBX10, the 20 actually does cost a measureable amount of heat. There's some floating tonnage, you can put it into a TC3 if you want: Straight forward build, literally. You run at the enemy as fast as you can, open him up and tear out his internals. omnomnomnomnom
