Mech is not available on smurphy ATM 6xMG, 2xMPL, 3xJJ, XL255, endostell, ferrofibrous, full armor except head (5 HP) MechDB link here _ Obvious stock upgrade with XL, JJs for improved mobility and extremely cool. It sucks it doesn't have any MG RoF quirk, but it should work.
This is the build. Devastating or a dud depending on your team and play, but hits above its weight, like an IS version of the Arctic Cheetah E. The arms want to fall off. Works on any map in the game, so it is excellent in quick play. Too fragile for faction play? I got 5 kills in this mech the first time I played it.
Nearly the same build I used but I down graded the engine to a xl 225. Fitted more ammo and jumpjets. Mean little fish.
Having run this at XL235 as a test, it's not a lot of ammo or jets that you get for the small weight difference. Remember that the XL255 comes with an extra heat sink packed in (which is what allows you to run ferro fibrous instead of light ferro fibrous). I think the smaller engines aren't justifiable on this variant of the mech. What is helping you survive longer? Speed or jets? Where can I get with 4+ jets that 2 or 3 won't take me?
I've been running this with 2 JJs and maxed armor instead of 3 JJs. I'll try it your way, but the weapon loadout is definitely sweet.
Great build! I like it with LMGs because they have roughly the same range as the MPLas. But it really needs those ammo skills.
5/5, Simple and powerful if played well in the late game when armor is removed and internal structures appear. I prefert version with MXPL, it synergis better with constant DPS weapons like MG. Dammages output are better in this way of play then classical MPL for a cost of more heat, but it's not a problem with this build. 3xMG, 3xHMG, 2xMXPL, 1xJJ, XL255 (15 dmg/s) jvn-11fl 6xHMG, 2xMXPL, XL230 - More agressive version with maximum DPS (16.8 dmg/s) but less speed. jvn-11f 6xHMG, 2xSXPL, 1xJJ, XL255 - MXPL downgrad to SXPL (14.8 dmg/s), less energy rang but absolutly no heat management. jvn-11f 6xLMG, 2xMXPL, 3xJJ, XL255 - If you want to stay at 300m of your target to avoid brawler builds. (12.1 dmg/s) jvn-11f
