Weapon Groups: 1. MLas (Mid Range) 2. MPLas (Close Range) 3. SRM4 (Close Range) 4. Alphastrike Alternate "Cool+" Version: Blagg
If you're going to run a K, I find it a good choice to put the tonnage from the second SRM4 (JR7-D) into MPLs for better DPS. I personally don't run BAP on my brawler lights, so I'd swap the XL295 and BAP for a XL300 and a heatsink. I also run my groups differently, the missiles require other aim than your lasers so I'd go for: 1: ML 2: MPLS 3: SRM and you can press everything at once (I just use the number 3 on my keyboard) for an alpha strike. Another option would be to drop down to an XL280 and give it 4 MPLS like so: I personally find an XL280 too slow though and I like the added ranged capabilities of the regular MLs.
I like the combo of the 2 Medium laser types. I'm very tempted to try this build, but I've found BAP on Jenners running under 40% going to the hot map's, have to limit their fire power, or risk overheating in the middle of the enemy. So, I would say 4-5 stars.
