Casual INC-4 "Sephiroth" (6xcHML, cLAP, cXL270)
1 rating
Thread in 'INC-4' started by Wckedmunkey, Mar 12, 2020.
  1. Wckedmunkey
    Wckedmunkey New Member
    This is what I run. Runs hot, if you couldn't tell, however its manageable.
    EDIT: If you can properly focus components, this mech plays surgeon. Fast enough to retreat if you start running a bit warm. IF YOU ALPHA, YOU WILL IMPLODE.
  2. If you did want to alpha... you can get close to this build.
  3. Wckedmunkey
    I hadn't thought of that. Ill try this soon. I just feel guilty for not using the other highpoint haha
  4. CarloArmato
    It looks good on paper.
    Instead of using an XL270 and cLAP, I would definitely lose a bit of speed to swap that cLAP with a TC1 for the laser range bonus.
    I thought to fit an XL255 and remove some armor to fit an additional DHS, but your build has a 2.0 alpha coefficiency pre-skills which looks very promising, so further reducing speed and armor in favor of cooling could be a bad idea.
  5. Wckedmunkey
    The only reason i went with a 270 is because of funding issues... haha. What do you mean about the coefficient
  6. Excalibaard
    5,051
    1,107
    Coefficient = how often can you 'alpha', AKA fire everything, before having to cool down. 2.0 means you can do 2 'alpha's approximately before you hit 100% heat. Adding another heat sink to make that 2.1 doesn't give you any more burst potential and the larger engine is a better choice. But, if that heatsink would give you enough dissipation to do 3(.0) alpha's, or the build was more focused around sustained fire, the higher coefficient would improve your build greatly.
  7. Wckedmunkey
    So, ive settled with an XL265, 6xHML, and 5DHs. I can Alpha in caustic valley, and only reach 97%.
  8. ShooterMcGavin80
    519
    My unit mate runs this. Has done some great work with it. Not a 'meta' mech due to the short range and long burn time, but man, if you play carefully you can really rip it up and have oodles of fun.
    Option for maximum cooling:
    He has reported that you actually can alpha on all but the hottest maps.
    Wckedmunkey likes this.
  9. Wckedmunkey
    Thats the truth. I've been averaging ~650-700 damage per match.
