Casual INC-1 "Leggo" (4xHML 4xLMG XL285)
1 rating
Thread in 'INC-1' started by Excalibaard, Sep 19, 2018.
  1. Excalibaard
    4,379
    973
    219
    Not quite a piranha, but not an ice ferret either.
    Max Engine to make the most of the few advantages you have. 4HML pack a punch and supported by a few DHS they should do well. 4LMG are in the same range bracket and add some heat-less DPS.
  2. JazzTheKamikaze06
    JazzTheKamikaze06 New Member
    I run a similar build with regular MG's and an XL270 and I love it. I will definitely give this a try. Are the LMG's worth it over the standard?
  3. Excalibaard
    4,379
    973
    219
    LMGs are quite good, but after some nerfs it comes down to personal preference whether you run light or regular. I prefer light because they have the same range as HML allowing you to play safer. They're not the main DPS weapons, rather a heatless 'boost' for when the enemy is opened up or your heat is built up. If you prefer higher DPS over the range advantage, go ahead by all means! :)
  4. ithinkiamawake
    ithinkiamawake New Member
    I run this with the stock XL170. Is very effective, the high mounts make for great peeking and the dead arm and 2Hml in the right arm make for a sword/shield combo that is very useful.
