Casual HSN-8E "Bigger Raven" (3xERLL, 2xJJ, TC1, ECM, XL280)
Thread in 'HSN-8E' started by CarloArmato, Dec 16, 2017.
  1. CarloArmato
    1,733
    515
    Long range sniper which makes the best use of the +10% range quirk, your hardpoint's position shouldn't matter that much and you can somewhat make use of the combination of range / being somewhat small / jump jets / (unskilled) ECM to dodge incoming projectiles. Best used at 540+ meters
    Keep in mind that the right arm has a +15 armor quirks: in the end it does have the same armor of the other arm
