Casual HMN-Prime "Medium Heat" (9xcMPL)
Thread in 'Huntsman Omni Builds' started by Remover of Obstacles, Jul 27, 2020.
  1. Medium range pop tart that needs to be fired in two groups. You can set up weapon groups for arms/torsos or left/right side.
    You will need to get some time to cool off or limit how many lasers you fire after the first alpha.
    Might get better with less lasers and more heat sinks.
  2. imhoopjones
    imhoopjones New Member
    i still think this runs way too hot...regularly have to wait to fire even with 8
  3. It is quite hot. Not quite KrevLL hot.
    You can get one more heat sink if you go to 7 MPL. But with the slots and tonnage you don’t have a lot of options. A slightly bigger opening salvo can sometimes be enough to take out an enemy.
    I recommend chainfire after the opening bursts. And be careful with jump jet usage.
