Casual HGN-733C "Triple Threat" (1xAC20, 2xSNPPC, 2xSRM6+A, LE325)
Thread in 'HGN-733C' started by CarloArmato, Oct 4, 2018.
  1. CarloArmato
    1,670
    496
    165
    Hot brawler: this is probably one if not the most pinpointy build given the hardpoints used.
    Use SNPPCs only when cool. Use only AC20 and SRMs when running hot. You can fire AC20 and SNPPC out of optimal range, that's why AC20 has more ammo compared to SRMs (30 AC20 strikes compared to 20 2xSRM6+A strikes). Also, you should use the empty arm as a shield
    ALT: remove 1 DHS for additional ammo, TC1 and/or JJ
  2. ShooterMcGavin80
    285
    39
    I came to a very similar conclusion on this mech, but 2xSNPPC is just too much. 1xSNPPC better IMHO:
    I'm skilling it up and it is quite fun. The JJ's are veeery important.
    Or you can lose the SRM's and just focus on the 40 pinpoint:
  3. ShooterMcGavin80
    285
    39
    Post skill up report: wow, I really like the 1xAC20, 1xSNPPC, 2xSRM6A, 4xJJ build. Naaaasty and repeatable alpha, fully skilled has quite good mobility, heat management, and survival.
    https://kitlaan.gitlab.io/mwoskill/...c62101cffff77ced86f1701000080af271b#s=Weapons
    I was fiddling around... and the Clan Highlander can aaaalmost pull off the 1xBig Ballistic, 2xPPC + 2xSRM6A:
    Might be a nice viable alternative to the more pure 1xLB20X 4xSRM6A 100% brawl build.
