This build is excellent. I used to be fearful of arm-mounted weapons as a result of the tendency for MW2's AI to go for those first, but this mech turned me around. It's amazing how much quicker the weapons track & how easy it is to do snapshots on off-line targets. When the Gauss nerf came around, I had the hardest time figuring out how the new setup worked, so as a temporary solution, I swapped the Gauss out for an AC-10 that happened to be in my inventory & added streaks with freed extra weight, though it does lose a heatsink: My original base used an XL280 without Endo and fewer JJs. Despite being a bit slower, it really does lay down the hurt. I'm kinda torn between PPCs and LLs myself. I agree with Fuzzy Bunny that the LLs seem to be easier to run (less heat per shot, capable of more damage), but there seems to be something of a greater psychological impact when using the PPCs. Great inspiration either way, can't wait to try similar builds on the Victors!
dropped in this build a few times 3llas/gauss/xl330/5jj and i have been pleased i thought i would miss not having some kind of missile. but i have to remember to KISS some times. and then you get matches like this when you do this was taken as of 2014/07/13 so gauss charge, jj shake, heat penalty for lasers, and fall damage would be your big nerfs with this build i have it mastered so heat even if i pop all three lasers at once really isnt an issue. i keep a 9x9 on me at all times so if it gets hot(which it hasnt so far) i would use it
Twice in the past month I have sat down to brainstorm from a blank mindstate a HM, and both times I've made this exact build at some point during the process... then I see it on this site, exactly like I build it (more or less in terms of armor). Just sayin. ps - haven't rated it, haven't even played it more than a couple times in game, I just simply keep building it in smurfy for some reason...
