Edit: this would be the older version Spoiler this is something I came up with after playing around with CarloArmato's tonberry. I really like the idea of taking advantage of the ballistic and IS gauss cooldown quirk. with full cooldown nodes you get a -32% cooldown on your HGauss . this build keeps the HGauss concept and replaces the 3 ERSL with 2 SPL keeping the same Alpha if you disregard the rocket launcher I just put it there as dead side bulk and something else to punch with, and if you don't like the rocket launcher you can always run with out it and replace the half ton of HG ammo for a full ton. Edit: after playing around with the mech and taking other peoples suggestions this is the revised version of the mech. the SPL have been swapped out for ML and the rocket 10 has been removed for more ammo but it can still be an option just swap out half a ton of ammo and pop that sucker in. another option you can chose is placing your arm mounted laser on the left, for those moments when you lose your side torso too early in the match; it just means your side poke game will have less gain Spoiler
What do you think about replacing the SPL with ERML or ML? Heat doesn't look to be a problem and it will give you a bit more range. Edit - Brett Lorenzo Favre
true I just had those for the fast laser duration but it can still be manageable with the ML burn time.
I've been running into other HGR GIs and I noticed that they didn't bother with the rocket 10 for that extra half ton of ammo and swapped the SPL for ML/ERML and I have to agree with that load out. Not having the rockets gives you one less weapon to have to worry about, and the payoff from that gimmick isn't really worth it unless the target is crit. but yeah 1HG 2ML on a 200STD is a great option for the Grid Iron but if arms aren't your thing then you should try Excalibard's High Grounder it's a much speedier version
Yeah I looked him up today he was a quarterback for the green bay packers I only picked that name because of Frank Caliendo's john Madden impression. Edit: and in spirit I stuck with the theme as close as I could Spoiler
