Need all 6 Energyslots filled with Lasers? Go for this. 16 DHS should cool down fast enough. Fire in Weapongroups due to your Heat Level. Weapongroups: 1. 3x MLas (Head + Arms) 2. 3x MLas (Hunch) 3. 2x SRM4s 4. 3x MLas (Hunch) + SRM4s (Close Range Strike) 5. Alphastrike Blagg
This is a really solid build and should work great. But I still prefer mine. A bit less firepower but with 8% more cooling efficiency, 200 more SRM ammo, and a bigger engine. Though, I do admit I lose the anti-missle system. I give your build 4/5 stars. I really do like it. It's nice to see others trying to use the 4J as something other than an LRM boat.
thx! About the 8% more cooling efficiency - dont be misleaded by that C.E. Value from smurfy. It may be a guide value for Alphastrikes, but in the end the actual amount of DHS counts! Example: 16 DHS definitely cools faster after firing 4 Medium Lasers, than 15 DHS or less, though the C.E. of the build is lower. Firing 6 Medium Lasers at 16 DHS will of course take longer to cool down than 4 Medium Lasers at 15 DHS, but on the other hand you actually have Firepower of two additional Medium Lasers for a much higher Pinpoint.Damage, which you can use in times of need. So thats why I recommend firing in Weapon Groups to deal constant fire pressure.
Love this build, I run it without the AMS because I have found I am usually fast enough to get into cover that its unnecessary. Instead I put the weight into the engine. First run with the build i did this. It seems a consistent mech for damage. Falls into the "alpha and run" category. Get 3 full alphas before needing to cool off. First 5 games using this build Wins: 3 Losses: 2 Win%: 66% Kills: 9 Deaths: 2 K/D: 4.50 match:
Bump for HBK-4J remodeling. I prefer to play with more speed and less cooling. You can downgrade to 15 DHS and a bigger engine i think
Not bad, but I prefer the tweaks added in this build a little more... Weapon Groups: 1. 3x MLas (Head + Arms) **(Linked Fire)** 2. 3x MLas (Hunch) **(Chain fire)** 5. 2x SRMs **(Linked Fire)** Module: 1: Radar Deprivation (forget the AMS) 2: Medium Laser Range 2 (really your preference)
