I decided to try something new and different. Yes, Gargoyles are laser-vomit brawlers and I've had a LOT of fun with mine. But I say, its time for a change. And with these quirks, its hard to argue! The quirks with this build: [no skills] Missile Velocity +10% ATM Cooldown -5% Base Armor (CT) +20 Base Armor (LA) +26 Base Armor (RA) +26 Base Armor (LL) +8 Base Armor (RL) +8
Lose on the spread, but no ghost heat and you gain an empty shield arm. Not sure how the quirks work out per pod, can you get the lasers to an arm? I would probably move the ammo to the legs to spread it out and avoid a machine gun light critting you out and leaving you with just two HSL. Looks like you will need the missile ammo capacity skills. PS I would consider shaving a bit of armor for another half ton of ammo, cLAP, etc.
