Casual FLE-17 "Striker" (6xMLas, MASC MK1, XL170)
Thread in 'FLE-17' started by CJPowell1337, Dec 5, 2018.
  1. CJPowell1337
    CJPowell1337 New Member
    30 point alpha mixed with a MASC MK1, this mech can pull off some great hit and run tactics. Chose MLas for the longer range, fits my playstyle more than the up close SPL versions, but the drawback is the longer burn time usually resulting in you standing still longer. Be careful out there.
    renzor51 likes this.
  2. CarloArmato
    1,388
    430
    165
    Locust version for comparison.
    I'm not sure the DHS loss for a MASC is worth it: it's true that you can reach 165 km/h without skills once MASC is active, but 145 km/h is more than often enough for most situations, plus MASC build is hotter... And switching MASC for another DHS completely nullify the reason to use a flea over a locust.
  3. CJPowell1337
    My build was fully skilled, hot but not too bad for the way I play. id probably drop a MLa before I dropped MASC, which still puts out more damage than my LCT-PB
  4. Jake Plissken
    Jake Plissken New Member
    I love this build, great with laser duration skills. You can surprise and fluster mediums in a heads-up fight if you spam toggle MASC and it's more flexible than the SPL version for quick play.
