As promised, here's the 'standard Dragon loadout' in all it's glory using the new tech from the Civil War upgrade. This is obviously based on @enileph 's old 'Roasted Lizard', which became a kind of standard build for the Flame and the 1C several years ago. The Dragons are benefitting a lot from both this and the changes implemented with the introduction of the Skill Tree, so use this to your advantage! First of all, don't worry about the armor values. There are massive quirks for those, which I even buffed a bit further by using the Skill Tree. You also want at least one of each ammo nodes here so you don't run dry early - in case of which you're still a fast, heavily-armored heavy mech with 4 fully articulated ERML. Play this as your usual fast GaussVomit mech and use the SRM6 for close range strafing runs, for finishing mechs already cored or in case of an emergency. Enjoy!
