Executioner Front/Rear Torso Hitbox Test
Thread in 'Executioner' started by Durandal, Jun 17, 2015.
  1. Durandal
    680
    That should give you a good idea of where to put your armor. It is VERY hard to lose/damage a ST from the front, so you can even remove some front ST armor if you want.
    epikt, enileph and The Verge like this.
  2. Durandal
    680
    And from the sides:
  3. Aylek
    We just tested this as well because we kept on dying by CT deaths in those things. Those CT and head hitboxes are a joke tbh... even with 110 armor I am dying way faster than even in a Dragon. This is ridicolous for an assault mech as you can't even effectively twist the damage - the CT can be hit from 90° left or right side as well.
    Long story short - fix this please @ PGI.
  4. Durandal
    680
    An update from Russ on Twitter today, there will likely be a hotfix tomorrow hitting both the EBJ cockpit glass accidentally appearing, and tweaking the EXE hitboxes. So these videos will be outdated tomorrow ;)
  5. Madgoose
    Madgoose Well-Known Member
    @Durandal : today
    Greetings MechWarriors,
    We will be rolling out a hot-fix on Thursday June 18th, tentatively scheduled for 3:00 PM PDT (10 PM UTC), with the following changes:
    Ebon Jaguar: Fixed an issue where the Cockpit Glass toggle was not functioning
    Executioner: Center Torso hit-box in the pelvic area has been shrunk
    • The Left and Right Torso hit-boxes now take up a larger portion of the pelvic plate
    Executioner: Center Torso hit-box in the chest area has been reduced significantly when seen from the sides
    • These side chest areas will now register as Left or Right Torso
    The estimated downtime required for this hot-fix will be approximately 30 minutes.
    When services are restored you will be required to apply a small patch.
  6. Durandal
    680
    Yup :p I'm trying to record some new hitbox videos now.
  7. Durandal
    680
    Now that we have the hotfix in, I got some help from Akula (thanks again) streaming two videos showing where the hitboxes are on each.
    Hope this helps! Looks like the EXE's side torso hit boxes should be a factor now.
    Hit the Deck likes this.
