Casual EBJ-C "Guerrilla" (2x cATM9, 4x cMPL, cAP)
4/5,
1 rating
Thread in 'Ebon Jaguar Omni Builds' started by Sixth Angel, Jun 9, 2018.
  1. Sixth Angel
    Sixth Angel New Member
    Break down the armor with the ATMs, tear off components with the MPLs. Absolutely vicious in the ATM sweet spot. Works pretty well if you can skirt around the edges of the brawl.
  2. Slimmed down low profile version with hero arm pods.
  3. Works well.
    Probably need ammo/armor more than the extra heat sink I added.
    Sixth Angel likes this.
  4. Sixth Angel
    Agreed. Had my record match for an EBJ in this build, actually.
  5. Excalibaard
    4,379
    973
    219
    Nice catch with the hero arms RoO.
    I destroy the low profile by adding a TAG which I believe improves ATMs a LOT if you can afford to run it. cLAP has enough range to counter ECM when you get in ATM optimal range, so that gives another half ton to play with.
    Overall, I like this build a lot. Very similar to my 4HML 2ATM12 TBR, or 2ATM12 5MPL MAD-IIC-B, but in a more agile package. The only thing it lacks are good missile quirks like the TBR or an MDD gets, but that enables a better energy/missile ratio because the quirks don't dictate which weapon will be most effective for once.
    rinco likes this.
  6. rinco
    rinco Well-Known Member
    I bought an EBC-EJ for ballistic goodness (click here for RoO's Black Cat). Then I realised the spare omnipods are used to make this monster. Two for one!
    Edit: I'm using an EBJ-D RT to get tag because the hitbox is smaller than the EBJ-B LT.
