Casual DWF-UV "Fireworks" (4xAC10, 10xERUL)
Thread in 'Ultraviolet Builds' started by renzor51, Mar 25, 2020.
  1. renzor51
    renzor51 Advanced Member
    354
    31
    So I saw a really cool build on Baradul's live stream some months back, and tried to recreate it using a DWF-W. I was hoping to get my hands on a DWF-W(S) with free twitch drawings (NGNGtv), so didn't want to buy a DWF-W, but it looks like the time of PGI-injected free drawings is over.
    I ended up just rebuilding it with my Ultraviolet, which isn't as optimal since I don't have the 'W' CT, but I found that using 12 ERUL's is too hot anyway because of ghost heat. I'll show the build for UV, and the build for the W below. Note, if you want to use 12 ERUL's, it's easy to shuffle things around and tweak it a bit, but there's a definite difference from the ghost heat. Not worth the extra 4.8 damage.
    Ultraviolet:
    My adaptation of Baradul's build on the W:
    Baradul's YouTube video he made after trying it on the livestream:
  2. I would consider running the Prime for more CT armor. I am not sure the hardpoints matter at ERuL range. More arm mounted lasers might be better for lights.
    If you don't need the jump jet, you could add in small lasers to the mix without triggering ghost heat.
    Or for a hotter take on things.
  3. renzor51
    354
    31
    Wow. Max of 29 DPS. I don't know if I've seen higher...
    Very hot though, yeah.
