Do you feel like the uac10s can be double tapped often enough? Seems like a pretty hot build and other 10-rating cannons may be preferable for the efficiency (though the scores don't lie ofc ;p)
Yes, it is a hot mech. Safer to run with Gauss vomit. You would have to drop ferro armor to fit in a LBX or a regular AC10. You can get in two alpha's with a double tap and then have enough heat left to keep the pressure up with the UAC10s. At this point there should be some open structure and the double UAC10s should make short work of it. Once the ten's jam, you have 6x MPLs with 21 heat sinks. That is workable. I still would run double cool shots and max out cooling skills.
For the ones that are curious about this build I've made a video that shows the potential of this brutal brawling build:
5/5, I've come around, and the 2xUAC10 + 6xMPL is definitely awesome. When you get hot you can stop shooting the MPL's and just keep rocking the autocannons. When the autocannons jam you can pick back up with the MPL's. My version: and skills: https://kitlaan.gitlab.io/mwoskill/?p=jsonbin1.5af67a23b24bee65e6f5f5ea#s=Weapons The 2xGR and 6xERML DeathStrike is of course also excellent. I have two Deathstrikes! Gauss vomit is the other one...
This is the mech i learned to play MWO with. Its simple to use, handles almost like a heavy requires heat management but nothing complicated. Went back to it after months of not using.... first match was ridiculous. 7 kills, mostly solo, 1600+ damage... like riding bike. http://imgur.com/gallery/gmbNNwp
