Deathstrike 'Hunter' (2xcGauss, 6xcERML, cXL375)
4 ratings
Thread in 'Deathstrike' started by Aylek, Aug 10, 2017.
  1. Aylek
    Skip those UAC quirks and go for full meta GaussVomit. Easily one of the most obvios, but most deadly builds on the Deathstrike.
    Skip half a ton of ammo, a DHS and some armor for a single JJ, which might become handy sometimes.
    Proposed Skill Tree: https://kitlaan.gitlab.io/mwoskill/?p=jsonbin1.598c075865ca45062e6332ef&s=Weapons
    Note that I took some of the velocity nodes because I skipped on a TC. This is totally up to personal preference, though.
  2. CarloArmato
    1,726
    509
    Very reliable build: don't be fooled by the simplicity of this build. A 72 alfa strike with excelent pinpoint will cripple a torso or could even be deadly if you hit someone who doesn't torso twist properly, and you don't need to be very close to fully apply your damage: with skills you can easily apply full damage up to 450 meters.
    I personally run a slower but cooler version featuring a TC1
    Trovidus likes this.
  3. Trovidus
    Trovidus New Member
    this mech is a beast!
  4. Trovidus
    Trovidus New Member
    best DS build so far!
  5. CarloArmato
    1,726
    509
    1200+ damage, last man standing.
    This probably is the build I scored the most 1000+ damage pug games. I would rate it again 5 stars if I could :D
    I also had my personal highest damage of all the pug matches I ever played.
    Foxhunter and Aylek like this.
  6. Excalibaard
    4,592
    1,003
    The sole reason you should get a DeathStrike, however edgy that name may sound.
  7. Excalibaard
    4,592
    1,003
    Adapted it to fit a TC1. Remove .5t of ammo to bump the armor values up, if you want.
    CarloArmato likes this.
  8. With skills you can run this build at 77.4 kph.
    It will be much, much hotter and a huge sustained dps loss.
    But if your team runs faster, maybe it will work for you.
    The Shazbot likes this.
  9. The Shazbot
    The Shazbot Active Member
    65
    Ono.... Not faster Deathstrikes.... pls... no
    Raddue likes this.
  10. Redshift Darkstar
    Redshift Darkstar New Member
    fast and has ferro fibrous, nice.
  11. CarloArmato
    1,726
    509
