Smaller but faster version of my custom Direwolf posted inside DWF-B "Alpha Wolf" (2xcGauss, 2xcHLL, 6xcERML). My version featured 2xcGauss, 2xcERLL and 6xcERML Even with better maneuverability, it does have the same firepower at the cost of worse heat dissipation (it should still be maneageable). Use it as the ultimate poker: aim carefully, alfa strike, hide, cool yourselves and then repeat. Not tested yet, but it should be manageable. EDIT: faster and slightly cooler ERLL version, still jump-jet-less for max heat dissipation.
This is the build I've noticed most "pros" using. Occasionally they switch out the HLLs for ERLLs when they want to go ultra-hardcore, since range is the thing nowadays, especially in Faction Play. I think they up the engine a bit, and throw in a JJ for good measure, which means fewer DHS, but I guess the speed might be worth it. I'd have to play it to compare the two.
