Cringe Build! - The Revival thread.
Thread in 'MechWarrior Online' started by enileph, Dec 28, 2015.
  1. Gneckes31
  2. krevLL
    krevLL Insane Fire Troll
    370
    115
    153
    "But I thought the annihilator had enough armor to make an XL viable..."
    So fantastic.
    This goes straight into this thread. It's just an obvious troll, and The only way you'd probably ever see this played is if you solo drop with me, but I give you all, the Predator.
    CarloArmato likes this.
  3. The Verge
    It has ECM, it's viable.
  4. And don't discount decent mobility with Tag plus large amounts of ATMs at short range.
    Now 3x Tag... eh.
    Decent alpha - adjust for heatsinks/ammo as you see fit.
  5. krevLL
    370
    115
    153
    This. This actually works, it's amusing since it started as a troll but with heavy mediums it actually works. Doesn't post stellar numbers or anything and heat management is a little iffy but I might keep this on one of my Hellbringers for a little bit!
    *EDIT* Since I can now consistently break 500 damage per match, this shall now be posted as a legitimate build in its corresponding section.
  6. Ruludos
    Ruludos Benefactor
    88
    51
    I dislike XL Assaults, but at least it makes sense when they boat heavy ballistics. But this?
    Missiles, PPCs and HMGs. Why go XL? People confuse me :S
    That's immediately after that KGC died, just to clarify.
  7. Tarriss Halcyon
    Tarriss Halcyon Active Member
    84
    Whelp; then you go the OTHER direction; and split your ballistics in a way that makes totally no sense.
    First game of the event and I run into THIS beauty of a King Crab. Clearly couldn't decide if he wanted to run boom or dakka; so he ran... both?
    Don't mind my Dire Wolf build; it's old but effective in mid-range brawls.
  8. The Verge
    @Tarriss Halcyon That looks like a viable build to me. 2xRAC2's to make the enemy fall back, 1xAC20 for a nice opener. I used to do that with Cataphract back in 2015...
  9. Tarriss Halcyon
    84
    My problem with it is more the fact it's a King Crab running that. As you said; you ran similar on a Cataphract. To me, this build is more something I'd expect on a Mauler, a Jagermech with a tiny engine or that one Cataphract that can run an AC20. He'd have plenty of ammo for each weapon system, but... I dunno; it feels kinda lacking to me for some reason.
  10. The Verge
    5xcLRM5...on a Jenner IIC...
    I have a personal hatred for LRM's on an Atlas, but when when they make it work...and win the game...
  11. Tarriss Halcyon
    84
    Hey; don't knock the LRM Atlas! There's just a very specific playstyle for it. Namely; run it with Large Lasers; and fight at around 300-450m. Basically; play like an MRM Atlas that doesn't have to peek to get damage off around walls. Share armor with the team; fight well. Two of my three Atlas run LRMs; though that's because one's a Fire support AS7-K (Gauss, 2xPPC, LRM 15 and 2xML) and the other is the LRM AS7-S (2xER Large, 2xMed, 4xLRM10).
    Now; the most recent cringe I've stumbled into: the largest HMG boat I've ever seen. Not sure the HPPC and Large Pulses can help with this one.
  12. Excalibaard
    4,645
    1,017
    Haven't seen this yet, but if I post it here maybe I encounter some trolls :)
  13. CarloArmato
    1,787
    537
    6xLMG, 2xMRM30 on a kingcrab
    So far, nothing extremely bad, despite lacking some punch... But then I too a look at the ammo count
    krevLL and Excalibaard like this.
  14. Gneckes31
    Talk about skewed priorties.
  15. IronEleven
    IronEleven Active Member
    The schizopult
  16. Gneckes31
    Ooooh, I saw a build like that recently..
    Here, I present, the Schizo-Stalker
    (actually, that sounds terrifying)
  17. Gneckes31
    And another one.. note the two TAGs...
  18. Ruludos
    Ruludos Benefactor
    88
    51
    If one TAG is in a torso and one in an arm, they can TAG two targets at once. Seems reasonable to me :^)
  19. CarloArmato
    1,787
    537
  20. Shock
    Shock Patron of the Underdog
    788
    325
    168
