Fun build I came up with. RAC2s really tear into the enemy and the heavy PPC helps mop up the leftovers.
I too have been using RAC2s to great effect on this otherwise underwhelming chassis. mixing in a HPPC with similar velocity is great to boost the pinpoint capabilities (and you can use the RACs as a tracer round). How is the heat of the HPPC in addition to the RAC heat in your opinion? I've been using Rockets for their crit abilities or SRM6s personally, the latter is already quite spicy heatwise in close combat. Also: thanks for sharing your build
On heat neutral maps the 3xRac2s heat isn't all that bad with the 16 heatsinks. The heat from the HPPC on the other hand is pretty high, so I use it as a nice little punch now and again when the 3 rac2s are getting close to jamming or I need to finish a mech off. Usually after I've taken some armor off.
