Created as a Light hunter. Especially vs pesky reeranhas, lolcusts and other rofleas... _ Code: Build: Am8D<:M0pH0]R7|BC|ZRqH0[R7|BC|ZRrF02S7|BC|ZRsF0>S7|oB|oB|oBtH0_R7uH0`R7v@09S7|m<2w:08080 Alternative build: _ You can replace cAP with additional ammo, or just use half-ton variants of each. Code: Build: Am8D<:M0pH0]R7|AC|ZR|l<2qH0[R7|AC|ZR|ZRrF02S7|AC|ZRsF0>S7|oB|oB|oB|ZRtH0_R7uH0`R7v@09S7|m<2w:08080
4/5, Tried a few rounds with the SSRM4 build and actually like this over other builds on the Prime. Because of the engine limit, I just hang around my fatties to help/protect them like OP intended. I kinda threw in AMS and a ton of ammo instead of more SSRM ammo on personal preference.
I would recommend tag so you can use those SSRMs. Lots of lights backstabbing assaults will have stealth or at least ECM. _
