COU-C "Pocket Ballistic" (1x cGauss, 6x cERSL cECM)
Thread in 'Cougar Omni Builds' started by Remover of Obstacles, Dec 17, 2017.
  1. Remover of Obstacles
    Remover of Obstacles Star Lord
    998
    383
    169
    With no ppc/erll, the gauss shots should be very hard to trace. With only one gauss rifle, do not try to trade with heavy snipers. Snipe and hide.
    6xERSL for bayonet range.
    Trade out for other ballistics as you see fit.
  2. Excalibaard
    4,348
    957
    219
    Enjoy the concept.
    I built one using HSL for slightly better bayonet alpha and only -C omnipods, in case the set-of-8 quirks might be useful. It's also perfect for the HSL which have ghost heat after mounting more than 5. It runs no ECM sadly like the -H head, but if set-of-8 isn't your fancy, the headlaser can be exchanged. Slightly lower range than the ERSL might make it too limited though.
  3. deman102712
    deman102712 Junior Member
    I love this build. People generally leave you alone unless you are just unlucky. 9 times out of 10 I can get all 30 shots out and on target just as the game is wrapping up. Otherwise I'm dead or I just go full Leeroy Jenkins with the lasers which has produced some hilariously confused enemies.
    Tollas669 likes this.
  4. deman102712
    Hadn't played it in a while. Forgot how fun it was.
  5. waaaaaaaat
    waaaaaaaat Active Member
    Yeah, love this build.
    Actually the one thing I want to say about it is that if you want ECM you have to trade a HS or ammo ton, and lose the ballistic quirk on the C.
