Casual COR-6R "Fafnir wanna-be" (2xLBX20, 1xSNPPC, STD325)
Thread in 'COR-6R' started by CarloArmato, Mar 20, 2019.
  1. CarloArmato
    1,679
    496
    165
    https://mech.nav-alpha.com/#bc257e45_COR-6R
    Simple brawler with an additional SNPPC for increased alpha strike. Due to the loadout it looks like a Fafnir, but with a SNPPC instead of an ECM. It looks like the right arm it could be used as a shield. If not, drop arm's armor and fit a bigger engine.
    Due to the fact it should be a very cool brawler, skillwise I suggest to max cooldown and survival: heat gen is not mandatory, operations can be completely ignored.
  2. Dagonus
    450
    115
    156
    This looks like it would be immensely satisfying to play; like a faster boomhammer with a snub.
  3. Dagonus
    450
    115
    156
    And here's an AMS version if you want the ability to simply deny the existence of most indirect LRMs now.
    https://mech.nav-alpha.com/#00c32314_COR-6R
    Shielding with an arm with a ton of ammo is less than ideal, but it should be the second bucket used so hopefully its used quick enough.
  4. Shock
    Shock Patron of the Underdog
    749
    B33f was running this with an extra Snub and smaller engine.
