Budget Commando 1B - 3ML+SRM4 Fast Recon/Striker
Thread in 'Commando' started by Toastygawa, Jan 9, 2019.
  1. Toastygawa
    Toastygawa Active Member
    52
    In early campaign or in Career Mode, Commandos are plentiful fodder to salvage. Mod the 1B model into a more survivable skirmisher. Hit-and-run tactics and high Evasion through Sure Footing + Bulwark helps this mech stay alive best (it's still only a 480 Armor Rating, so be careful).
    **Adjustment: Put SRM Ammo on RT or RL and use LA to shield when needed. Drop some back armor to make that an SRM6, but focus on your facing.
    Pros: More survivable than stock, almost 100 Alpha, SRM ammo for 25 rounds.
    Cons: Still a Commando (not likely to survive 25 rounds), no JJ.
    This build shown using standard equipment. Using + or ++ is unrealistic and not recommended on a mech this lightly armored.
    I like this forum for reference, and thought I'd round out the lesser-represented mechs, especially since Career Mode brings them back into play.
  2. Toastygawa
    52
    A bit more practical: 2ML and an SRM6 allows for more consecutive turns of constant fire at very nearly the same damage. This configuration gives you a shield arm and torso as well. Same suggestions apply as above, with the addition of the LA shield.
    Adjustments: Cutting leg and back armor more can give you one SL, but this mech loses limbs quickly if you go lighter.
    When I start a new Career, I remind myself of the value of the bitty mechs.
