COM-2D "Sneaky Boi" (3xSRM2, ECM, XL210, Stealth)
Thread in 'COM-2D' started by IronEleven, Jun 2, 2018.
  1. IronEleven
    IronEleven Active Member
    Pros:
    • Combination of stealth, hitboxes, quirks, and speed makes it very hard to kill
    • Annoying as hell
    Cons:
    • Pitiful firepower
    • Most of your firepower is on one arm
  2. Excalibaard
    5,055
    1,107
    Burst may be low, but SRM2s fire EVERY 2 SECONDS with minimal spread. So basically this is an AC10 on steroids.
    I've had several great kills in my 4SRM2 locust and I imagine a stealth mech lives longer.
  3. Guyver
    Guyver New Member
    how do you engage with this spec? pop stealth armor, firing missilles, heat going up until threshold and then going away to cool off?
  4. Excalibaard
    5,055
    1,107
    probably worth to have stealth armor for running away, when firing you draw attention anyway. Walk in with stealth, disengage it after a few shots, turn on when you have to bail.
  5. IronEleven
    I usually disengage stealth armor once I'm committed to a fight.
  6. Napalm1473
    Napalm1473 New Member
    mind posting your skills?
  7. IronEleven
  8. The Shazbot
    The Shazbot Active Member
    71
    Bro holy shit... Just bought this 10 mins ago, built it like this, saved it as a template called "Sneaky Boi" then came on here to check out builds and saw this xD
    Great minds think alike, I guess!
  9. Excalibaard
    5,055
    1,107
    Your subconscious may be browsing the forums as you sleep ;)
  10. IronEleven
    Alternate build here
    Drops 10 engine rating for slightly higher DPS and being 50% less screwed if you lose your right arm
    Nekromanteia likes this.
  11. FaustHammer
    FaustHammer Benefactor
    I very much enjoy this build. Not a huge damage output but you can just creep up on enemies and put on air strike right behind them easily. Great finisher mech.
