Name is obviously a pun: it mixes Orochimaru with Mario (you know... Centurions were roman commander) _ Why this version instead of the more common, tonnage wise better and with identical alpha strike 3xSRM6+A + 2xML STD engine version? Because LPL will reload faster than SRMs, so if you torso twist between shots you can always alpha strike once your SRMs are ready (so you won't have to perform "half-alpha-strike" every time). It's definitely hotter and definitely more susceptible to a side torso loss, but it seems it is worth a try. ALT: LE270 version. Slightly slower, but maxed leg armor, 16 head armor and more armor on shield arms. _
