The 3C seems to be the stepchild of the CDAs, but I somehow seem to have a weakness for it since I discovered the beauty of Enileph's Fire & Brimstone build. This one works similar as it allows for sustained sniper work with ERLLas and AC2. In addition to this you can also close in on your opponents when it comes to the second half of the round and start to rip cored parts apart. The mech is fast enough for repositioning yourself quickly and uses full armor on every part but those arms. Slight variation: Using an XL285 in favor of another ton of MG ammo should be possible as well. As the 285 is pretty uncommon a 280 sized one would be possible as well, but which leaves half a ton of free weight. You could either add armor to the arms or strip the arms and other parts a bit to add an additional DHS.
