How many time you heard people asking "Get on top" then they give up on the idea and join the nascar? Worry not, this build is made to achieve that. _ Big but pinpointy alpha, quite hot, quite slow for being a brawlish build but excellent hardpoints. If you feel low on ammo, strip a bit of armor and add another half ton of MRM ammo. ALT: you can swap LPLs with LLs, so you are sacrifing a bit of alpha and laser duration to fit a faster LE350, +1 DHS and fit that additional 0.5 ton of ammo without the need to strip armor... It's actually a lot cooler and probably better fit for an actual prolonged brawl, top poking or actual nascar. _ 7 If you love the idea, you can strip half ton of armor and actually fit a TC1 for improved laser range (it never hurts, especially due to lack of ML range quirk) _
