BLR-1S "A PerfectDuck Inspired Battlemaster" (4x ERLL, XL400)
Thread in 'BLR-1S' started by Epydemic2020, Mar 14, 2015.
  1. Epydemic2020
    Epydemic2020 Well-Known Member
    115
  2. B0ilz
    B0ilz Well-Known Member
    210
    62
    As fo right now I'm fairly certain the energy range quirks are up to 25% more now, so you'll have even LONGER range. ;)
  3. Remarius
    Yeah I still have this build from the day Battlemasters hit in the pack ... using the 400XL from the Boars Head. ;)
  4. El Nota
    El Nota New Member
    This build really works. If you can stay away from the enemy, lets say 1200 meters, it helps to avoid any problem with the XL400 engine and still do a significant amount of damage. Have a lot of matches with +1000 damage. Also, you can use a STD 340 engine if you dont like the XL.
    Five stars for me.
    Epydemic2020 likes this.
  5. Trygger
    Trygger New Member
    I use the same 4erL build with a 325 standard engine and the command console. It works really well for CW against clans, with the 911m laser range. The console helps the advance zoom to aim a specific torso even at 1500 range. The weapons and cockpit are really high mounted on the mech so find a ridge and snipe.
  6. HKO2006
    HKO2006 Active Member
    83
    3ERLL, 22 DHS, TC3, you can alpha 16 times without overheat with this one
    21 DHS, TC4, XL
    19DHS, TC6
    18DHS, TC8
