Due to BJ low weight, i think is best to rely as little as possible in ballistic weapons. Instead i placed LLas so u can "snipe" and a ton of JJs to increase maneuvering. Also armour is quite straight forward, in the front, so the little numbers still count. And other version with XL engine. More cooling and speed. Slightly less armour, but i took it from the head and legs. Hope u enjoy them
Bigger STD engine: Less JJ, but you won't poptart with this mech anyway, it's just for basic mobility. (a second jet can be added if you shave a little armor)
Thanks for the input, i like the idea, but instead reworked it around a STD200 to get the best of both worlds; more speed, 2 JJs and 1more extra Heatsink
I question the utility of the third ER. I would set up a short range bracket to compliment the machine guns. Either dual mlas, splas or mplas. Also I think you could cut the mg ammo by half and still be fine.
I have been testing the mech and is fine for a BJ. The 3rd LLas allows for chain fire, and the MGs are there for close quarters protection and crit exploit. So far is fine and is turning funny to drop with
I've played this loadout a lot of times... it is really useful. is what i play right now. some times i swap the 3rd ERLL for two mplaser
