MechDB link Original omnipod set quirk: -15% ballistic cooldown Exploiting high hardpoints and cooldown quirks. When hill poking, if you can see a target you can hit with the 3 highest energy hardpoints. The 4th is slightly below cockpit, so you will have to expose a little bit more. Hill poke, charge up and fire gauss as soon as it is ready while firing ERLL first and LPL later, then finally hide and you will be fine. You can switch 2xcLPL for 2xcERLL for a total of 4xcERLL for maximum range, pokiness and further add cooling. Your choice.
