Casual BAS-B "Looky Luke" (3xUAC5 2xHLL cECM)
Thread in 'Blood Asp Omni Builds' started by Excalibaard, Oct 20, 2018.
  1. Excalibaard
    4,475
    988
    219
    Another build that uses the towering hardpoints of the BAS to exploit a medium range monster build. Spoopy!
    Nekromanteia, rinco and Lorgot like this.
  2. Lorgot
    Lorgot Advanced Member
    347
    68
    Similar optimal range and cooler
  3. Excalibaard
    4,475
    988
    219
    Made one with slightly more alpha (still don't like the hardpoint locations #3 and #4)
    Nekromanteia likes this.
  4. Lorgot
    347
    68
    IMHO I think erml and HLL are way to hot nowadays, so using lpl and mpl is preferable, even with the quick heat dissipation, alpha-ing with all the lazors would bring you to about 75 percent already, so you would need to back off quickly
  5. Excalibaard
    4,475
    988
    219
    I have been debating between the two. I agree that LPL have better D/H ratio and superior DPS, and even 2xERPPC is cooler than the 2x(HLL+ERML). However, the alpha and suppression of the HeavyLaser/PPC choice are perfect for a peeking strategy with your high mounted weapons. They're two different playstyles.
    I'd choose LPL if I'm pushing and want consistent damage dealt up to 650ish meters. It's great for putting out intense damage numbers and focused damage.
    I'd choose PPCs/HLL+ERML combo if I want to fire/double tap once, and cool in cover afterwards (either moving forward during the suppressing duration of my lasers, or going back behind the hill). For that it may be better to run the dual UAC10 instead though because of higher alpha.
    Thinking like this makes me realize I'll use the LPL variant you suggested. I already have a hot alpha BASP using UAC10s with my 2UAC10 6ERML build, and a cold brawler with 2LBX20 3SRM6. That leaves a long range DPS strategy to separate this BASP from my others, which your build is best for.
    Adapted for the BAS-A which has an annoyingly heavy CT Jumpjet I have to work with, I'd get this (might exchange a ton of ammo for another DHS):
  6. KarbonKopy
    KarbonKopy New Member
    Came here to post the 2xHLL and 3xcUAC5 build and boom here it already is. Hard to have a poor match in this 'mech unless you are caught in a bad spot. Just had another amazing game. Deadly as hell.
  7. Excalibaard
    4,475
    988
    219
    Incredible, haven't done anything close to that in a BASP yet.
    KarbonKopy likes this.
  8. Nekromanteia
    Nekromanteia Junior Member
    31
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    Man there's more SS but I think this should be enough..
  9. Nekromanteia
    31
    ^ Refer to SS above. Awesome!
