Meme AWS-8Q "Stupidity" (3xHPPC, 3xLPPC, LE280)
Thread in 'AWS-8Q' started by Wattila, Mar 20, 2021.
  1. Wattila
    Wattila New Member
    You can fire both the HPPCs and LPPCs back to back with some heat skills for 72 points of PPFLD, nothing more needs to be said.
    ShiverMeRivets and krevLL like this.
  2. krevLL
    krevLL Insane Fire Troll
    383
    117
    153
    Perfection doesn't need alts, and this is perfect.
  3. ShiverMeRivets
    207
    46
    I gave it 5 stars for the name alone :)
    I really have to try this build. Will probably work even better with 6 regular PPCs.
  4. I was looking 6xERPPCs. The ERPPCs are much hotter. I am not sure you can actually pack enough heat sinks to make that viable.
  5. krevLL
    383
    117
    153
    It's not the heat sinks a mech needs. Just internal structure, consider it a form of... trading. You trade your life force to run more hot things. With override and internal structure, who needs heat sinks?
  6. krevLL International Dictionary
    Viable - any build that does not instantly self-destruct when fired.
    Ch_R0me, Excalibaard and Shock like this.
  7. ShiverMeRivets
    207
    46
    Internal structure won’t save you when the heat destroys your weapons before the components fall off. Worse - internal heat damage destroys your DHSs, which lowers your heat capacity, which leads to more heat damage...
  8. Ch_R0me
    Ch_R0me Benefactor
    Awesomeness brought to the ultimate level. Well done.
