Rest In Pepperoni. Either you get the kill... Or the kill gets you. Alternatively you can sacrifice a bit of beam duration for a 3xLL + 1xERML alt; Ended up running a slightly different Alt; 3xHPPC, 3xLL, XL300, Endo and DHS
There is room for Light Ferro. Added some armor, moved the LLs to arm to deal with lights inside of 90 meters. Fun mech to play. Can't really front line with it.
'Mildly hot' version with standard PPCs: despite the nimbler 57 damage alpha (instead of 72), according to mechDB it can alpha strike twice, it has better cooling (+3 DHS, +20%~ heat/s) is faster and overall has better survivability. _
I'll probably do the LFF option, I usually just lock my arms anyway so I can get maximum alphastrike potential but it absolutely is no good as a front line tank. Carlo's gives better Survivability, but in the end the heat containment penalty to losing a ST probably makes it somewhat useless too. It's satisfying to see armor either turn red or disappear completely on a relatively fresh mech with the 72 damage though~
