I bought the AS7-K recently and needed a good build. Since there aren't many 5-star builds on the AS7-K page, I went looking for a better way to loadout the AS7-K variant. This build was inspired by dranozir and his posted build. No better place to start than learning what worked in the past, and going with it. This build trades 2.7 kph and 1% heat efficiency for 2x AMS and 2000 rounds. It also has two ML in the center torso to keep dishing damage til' you're dead! (losing the arm mounted light mech defence...) Thanks to dranozir for the inspiration! -mmstahlman
Not much to improve really If you are very good at heat management, you can trade a PPC for the ER. You might find yourself needing to snipe with the single PPC tho, from time to time. Right side look better for brawl setup, 30 pinpoint all on the same side. Or if you find yourself loosing too often the AC20 side first, you can keep the ERPPC in the other hand, so once AC20 side is gone you still have 20 damage that works close range (gonna be pushed once you loose the AC20). Keeping it in the left side might be the best choice tho, because once the left side is lost you drop a lot of DHS. You will be @ 37% eff. when mastered.
