Simple Zombie Atlas built as fast as this Variant can go, big alpha, and a high mech score(time to over heat x Maximum dps) of 285 damage. Delight in dwindling down to fewer and fewer pieces of a mech while still pumping out damage at close-mid range. The Lpls fight off lights well and brawl well, while the AC10 bumps the alpha and can be used to sustain dps once you top out your heat. To make it a little more brawly, Switch the ac/10 out for an LBX 10 and and play with the armor a bit. Up the back armor if you need it, but you don't want to go into a fight with an assault wondering who has more Front CT armor so be very conservative about it.
