Taking the standard 5xLBX10 build and substituting a RAC5 for screen shake and a bit more damage up front. I need to test how bad the heat builds up and ammo consumption. Should be plenty of LBX ammo. The ML helps avoid ties in case they take off you STs and a bit of extra dps if you can spare the heat. If someone has tested 2xRAC5 - 3xLBX10, let me know if it is indeed too hot to run well.
