_ Spoiler: Previous iteration: -1 DHS, XL300, +0.5 tons ammo _ Don't use both weapon groups: use only one of them depending on your range of engagement and/or target. Snipe as much as you can with those ERLL to achieve the most free trades you can. You have the speed to follow your team wherever it goes, so try to support the nascar / push / firing line as much as you can but keep your distance: do not join a brawl unless your team is expected to win in moments. When moving in for a brawl you have an higher risk of being damaged in the process, so follow the previous tip: free trade as much as you can. In the end, if you are the last or onne of the last survivors it will either be one of the following cases: your team got brawled to death and there is a bunch of brawlers hanging around, waiting to be kited to death while they are attempting to close the distance on you... Or hopefully being finished off close range with your 4xSRM4s some snipers killed off your last brawlers, so you can either try to snipe them back or brawl them to death thanks to your superior speed and maneuverability. When played correctly, you are probably either gonna be hated or praised depending on the match result. If your team get stomped (11 team death and 0 to 4 kills achieved) you are going to die anyway regardless of your build, so don't worry. Recommended skill tree: https://kitlaan.gitlab.io/mwoskill/...0c271ccf37f000000000070a5df76000000#s=Weapons ALT: higher SRM alpha strike, but slower _
