Casual ACW-1 "9-9" (9xcATM3, cXL225)
Thread in 'ACW-1' started by krevLL, Sep 8, 2018.
  1. krevLL
    krevLL Insane Fire Troll
    275
    3 weapon groups: 1 for 4 launchers, 2 for 5 launchers (or 4 to avoid ghost heat), and 3 to chainfire all 9.
    You aren't fast, just quick. 91 kph so stick with the heavies and assaults. When they engage a target, you dart around lobbing ATMs at them. If there isn't any AMS, chain it: It's almost constant with 9 launchers. If there's AMS around then use the other two weapon groups. No way around the fact that it sounds like a pea shooter but if you're in a brawl and under 270m you're dealing 81 damage every time you fire off your 9 launchers, and that's roughly 5 seconds.
  2. anamiac
    anamiac Well-Known Member
    140
    How much shielding do you do with your arms? If you don't, then this is a slightly cooler option:
    krevLL likes this.
  3. Remover of Obstacles
    Remover of Obstacles Star Lord
    982
    372
    169
    Fun build to play around with.
    krevLL likes this.
  4. krevLL
    275
    @anamiac I don't shield really, not with this mech. Maybe if I was running something more like SRMs but with the ATMs I'm generally with enough bigger mechs' that I get ignored. The bigger launchers are cooker overall, but my idea here is just like a 7xLRM5 build, mostly harassment when an enemy is caught without cover, and to cause enough cockpit shake that they can't properly aim at your assaults.
    @Remover of Obstacles that seems to have been a pretty decent game for dealing damage. I can't remember my best in it, 700 some damage and a few kills I think.
  5. Remover of Obstacles
    982
    372
    169
    @krevLL Usually the damage is lower and the kills are much higher. I was able to get some great positioning in polar and work the hills. The tighter spread usually works well for finishing. Also, very little AMS. AMS really hurts ATMs.
